Pump not primming, but runs fine
Old 07-14-2012, 03:47 AM
Z28MJ's Avatar
Default Pump not primming, but runs fine
I noticed the other day that my car was real hard to start, so I checked into it and the fuel system is not priming right. When I turn the to on, it pressurizes it to 30psi but as soon as it hits 30psi you can hear something kick and it drops all pressure. Once I get it started it runs fine. What controls the priming? Thanks
Old 07-14-2012, 11:10 AM
LS1TECH Sponsor
Lonnies Performance's Avatar
It sounds like it is priming correctly but it is not holding pressure.
It only primes for approx 5 seconds.
If your pressure suddenly drops after the prime, you likely have a hose leaking in the tank, a bad regulator or an injector leaking.
Old 07-14-2012, 01:13 PM
Z28MJ's Avatar
ok I will look at those and go from there. thanks
Old 07-14-2012, 01:47 PM
Z28MJ's Avatar
It was the feed hose in the tank, you are my hero. Now for a question, when I first bought the car last year, the hose in the tank was cracked. I replaced it with rubber injector hose and it did not hold up, what can I use to replace it with?
Old 07-14-2012, 09:03 PM
LS1TECH Sponsor
The factory flex hose is what you need.
Rubber will fail....
Old 07-14-2012, 10:33 PM
Z28MJ's Avatar
yeah, I found out that rubber fails the hard way haha. Where do I get a factory flex hose? I never could find one except with buying a hole new bucket or a pump kit.
Old 09-07-2012, 10:00 AM
Hawaiian_Built's Avatar
I'm having this problem in my truck. Hopefully its just the line.
Old 09-07-2012, 10:57 AM
TAChief's Avatar
any fuel ine that meets SAE 30R10 will do. This is a very specific requirement.
http://www.gates.com/brochure.cfm?br...ocation_id=541
http://www.oreillyauto.com/site/c/de...0887&ppt=C0222
Old 09-07-2012, 05:21 PM
Ollie8974's Avatar
2X what lonnie said.
Factory Flex hose.
THIS IS THE ONLY IN TANK HOSE TO USE.
http://www.racetronix.biz/items.asp?...atus=0&Tp=&Bc=
Old 09-22-2012, 08:20 PM
I'm glad this thread was started as it gave me somethings to look at. I have to prime my truck about 3 times to get it to start. The first 2 times I can hear the pump but its faint. Around the 3rd time it sounds normal.
I pulled the fuel rail out to check for a leaky injector. didnt find one. I then pulled off the main fuel line to see if I was even getting fuel while priming. I let it prime once, checked the line and there was nothing. So I primed it 3 times and then I heard the pump get louder and then there was fuel coming from the line. Next thing to check is the intank hose. Does it sound like this hose is the problem? I also already swapped the fuel reg.
Old 09-23-2012, 07:03 AM
Ollie8974's Avatar
Factory Flex hose.
Yes, replace the in tank hose.
Ollie8974's Avatar
Factory Flex hose.
As above.
Quick Reply: Pump not primming, but runs fine
