in tank regulator bad ?
Old Jul 17, 2012 | 06:35 PM
devic's Avatar
Default in tank regulator bad ?
i just put a racetronix fuel pump in and im only getting35-40 psi
do u think this is the in tank regulator, and at this pressur will it cause the car to not stay running
Old Jul 18, 2012 | 10:57 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Did you have low fuel pressure BEFORE swapping in the new pump?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jul 18, 2012 | 09:21 PM
devic's Avatar
the old pump didnt work at all, why i put the ractronix in, at first i had 0 ps1, then took the regulator out the tank cleaned it put it back in now its at 35-40
will this low of fuel pressure casue it not to run ?
