boost reference regulator leaking
Old Aug 14, 2012 | 11:49 PM
a4ls2goat's Avatar
Default boost reference regulator leaking
I'm having a issue with my regulator.
Everytime I rev the motor passed 4k rpm or so the boost reference nipple on the regulator spills a little bit of fuel. It's not a lot but it does seep out under load.
It does not leak while normal driving.
My fuel pressure is solid at 62psi and does not drop.
The regulator is a SUMMIT boost referenced regulator.
What can be causing this?
Old Aug 15, 2012 | 06:18 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Most likely the diaphragm is bad in the regulator.
Old Aug 15, 2012 | 06:48 PM
98Camarod's Avatar
are you boosted and it stays at 62psi?
Old Aug 15, 2012 | 09:40 PM
a4ls2goat's Avatar
that would suck, as its a new regulator
Old Aug 15, 2012 | 09:41 PM
a4ls2goat's Avatar
yes it does
Old Aug 16, 2012 | 04:22 AM
98Camarod's Avatar
yes it does
It should rise 1lb per 1lb of boost. something doesn't sound right.
Old Aug 16, 2012 | 07:14 AM
a4ls2goat's Avatar
Obviously I can't see if it leaks under WOT while driving.
This is if you rev it while parked.
Old Aug 16, 2012 | 10:36 AM
salemetro's Avatar
It should not leak at all...ever.......time to return it.
Edit: It also sounds as if you don't even have the reference port hooked up....as you're able to see a leak out of the reference port. As has been said previously, fuel pressure should rise 1lb per lb of manifold pressure increase.
Old Aug 16, 2012 | 10:49 PM
a4ls2goat's Avatar
i dont have the reference port connected because im currently not going WOT.
and i know if i hook up the port it will rise 1lb per psi.
Old Aug 20, 2012 | 03:59 PM
a4ls2goat's Avatar
Called up summit racing.
They are sending me a new one even though it was out of warrenty
Old Aug 22, 2012 | 01:03 PM
MIGHTYMOUSE's Avatar
never should be fuel on the air side.
