Confused about ordering injectors...help?
Old Oct 6, 2012 | 12:15 PM
camaro75racer's Avatar
Default Confused about ordering injectors...help?
Ok i need some bigger injectors so started shopping around but im confused as to what style to order. The cars a 02 z28 with the stock ls6 intake/fuel rails. Do i want the short or the tall injectors with the EV1 connector? Any response is greatly appreciated.
Old Oct 6, 2012 | 12:30 PM
nick.celis's Avatar
you want the EV1 injector. EV6 and you will need adapters.
Old Oct 6, 2012 | 01:33 PM
FICINJECTORS's Avatar
Ev1 is the designation for Bosch 1st design, the commonly called ev1 plug is actually called a minitimer plug. this plug comes on the pencil style Bosch design 3 which is a ev6 injector. the newer style plug that is commonly known as ev6 is actually called a uscar connector and is available on all series of injectors made today from Siemens and Bosch. we have the ev6 injectors in all sizes from 22 to 80 lbs with the old style mini timer plug.
Old Oct 11, 2012 | 03:29 PM
ZL1Killa's Avatar
and you want the tall injectors, 60mm
