To much fuel From where?Help
Old Apr 12, 2004 | 04:25 PM
98PepperZ's Avatar
Default To much fuel From where?Help
I changed headers and ever since the car is hard to start and afterfires though the exhaust blowing flames! I have changed intake, pcm, O2's, heads, cam, and map sensor. The pcm sets no codes, even had a Tech2 hooked up and found no misfire on any cylinder. Could the fuel pressure reg. be allowing to mush fuel through to the injectors? I need some advise to get my car going asap!
