FI Fuel setup. 800-900rwhp
ZL1killa,
To answer your question, i like to do things myself so I know they are done right, and it saves money. If i screw something up its no one's fault but my own.
Not attacking anyone, but the only responses I see in the fuel section from venders is "call me i can help". Once you call these venders their only solution is to spend more money and more money. I prefer not to send my money to a vendor that is overpriced, with no knowledge or factual answers when you ask a question.
How are people like skinnies making 900hp with simple and cheap setups, but when i call a vendor it is over $1500 to do the same?????
ZL1killa,
for my fuel setup I have a racetronix 255 in-tank kit w/harness that is always on. I then have an external in-line pump & filter & FPR, Bosch 044, aeromotive FPR & Filter with a MSD switch for turning on at 1psi of boost. With all lines stainless braided & BLACK AN fittings, etc. This cost me ~$1k ~1.2K TOTAL. Done finished not having to worry about anything.
This is no different than any other vendor/manufacturer in the world, it is always a hey you can go to here and here and buy this and that and put it together and here is the writeup and its going to take you all day.
OR, hey I sell this kit for X amount more and its all you need you don't have to drive all over town and order multiple parts from multiple places and piece it all together.
All we have done so far is tell you that your concerns over fuel heating is not necessary. PM me if you want to discuss some pricing, I don't see why you can't get it done for less than you have first posted. The only kicker is injectors alone are going to be ~700~800 bucks, so for certain with fuel line, pumps & electrical wiring & FPR you will be above 1500 TOTAL; I don't know what you are referencing your 1500 on.
i love the fuel section! you guys crack me up!
1. in reality -6 feed is enough.. i went with 8 at that level for safety. pretty eye opening for anyone interested in doing the math. even at 1300 horse i was using the stock feed for return (if you stagger pumps you dont need to return as much) which is smaller than -6
2. dont run anything to bottom of tank without a sump, put pump(s) in the tank or a siphon to factory pick up point.
3. see attached
4. yes!
3. see attached
4. yes!
Plan on doing a twin turbo setup with an AES390 next spring. I need a fuel system that will keep up. Have a couple of questions. Goal power is 8-900rwhp
My plan was to run a Magna fuel 4303 pump. Their FPR. braided lines, fast fuel rails, with 80# injectors.my questions are..
1. i plan running a -10 feed and a -8 return, will this be enough? And how much barided line will i need in ft?
2. How can i run a line from the tank to the pump? is there a fitting i have to put into the bottom of the tank?
3. How do i run my lines from the pump to the rails and FPR? a diagram would be great. for example. do i run from the pump to the FPR to the rails and then back to the pump? go to the front of the rails or rear for the feed etc..
4. Can i get this done for $1500 or less? i have a tight budget m working on.
Thanks.
Thanks.
3. see attached
4. yes!
3. see attached
4. yes!
i have used this kit on several cars, very good quality (through scorpion)
http://www.summitracing.com/parts/su...0/media/images
or
http://www.summitracing.com/parts/hl...9/media/images
this holley kit looks like a great bang for the buck without any of the cheap-o parts you find in other kits cough performance products cough
http://www.summitracing.com/parts/hl...0/media/images
or
#33
I ended up going an Aeromotive belt drive fuel pump. Won't cook the fuel as much. I want to be able to make 1khp and drive 7 hours on the highway. Not sure on feed or return size though. Probably 12 feed and 6 or 8 return. I overkilled mine incase i want to run e85. Holley fuel rails that came with the intake and FIC 2150 injectors.
