Injector Size
Old Nov 27, 2012 | 06:38 AM
ss4chad's Avatar
Default Injector Size
Just got my new 427 motor stabbed in the car and I am thinking about having it tuned on E-85 since it is available in my area. I have the Ford Green Top 42lb injectors (flow matched) now but should I upgrade those to a 60lb (higher-lower) to run the E-85?
Will the Green Tops fair well with alcohol?
Is the 42lb enough or too much for running E85?
Chad
Old Nov 27, 2012 | 11:37 AM
ZL1Killa's Avatar
I would go ahead and use 80LB injectors... maybe even 100LB. You have to figure you might as well double the size from fuel to e85.
call FIC - Fuel injector connection
Old Nov 27, 2012 | 02:11 PM
ss4chad's Avatar
Called FIC, they recomend 58-60lb injectors. So it looks like i will be selling mine.
Chad
