Help Dual Pumps not working
Low volts will cause the problem.
Poor wiring.
Walbro overheat?? Nope, not w/ those I've used.
What's the fuel psi?
Return system, or deadhead?
What are you using for a tank vent?
What does a blower have to do w/ fuel @ 42psi? What injs are you using?
Voltage at the pump[s] is?
How are they grounded?
I already gave pointers to try concerning the tank venting.... did you try these yet???
Also since the car did the same thing with the previous fuel pump, it is not likely any part of the kit (pumps, lines etc.) is causing this, but rather a pre-existing problem.... hence the reason I told you to verify the vent first & call me back.
Since I did not hear back from you I will assume you did not do this?
Verify & call me rather than going on a wild goose chase.
GL Lonnie!
Again my reason for coming on here is for the advise from the experienced guys and people who have gone through this before. Thats all!!
GL w/ the fix.
Experience wise, after building well over 1000 dual pump kits, I can likely point you to the problem without a lot of guesswork.
Problem is that after one pump stops working, the other still works, then vice versa.
This points to an overheating or cavitation problem.
You had this problem with a full tank of gas, so 1 pump will not overheat 15 gals of fuel in 30-40 minutes... especially in the winter months. Did you fill the car up again before trying the same experiment? You cannot get repeatable results using different situations. If it acts up twice as fast with half the fuel in the car, I would not be surpriced.
Both pumps have independent circuits, so a single wiring issue will not cause the same problem with 2 pumps.
This leads me to think something is causing cavitation.
Repeatedly cavitating a pump will cause it to fail.
It basically is running dry & self destructing.
Did you check the tank vent as described or drive the car with the cap loosened slightly?
After the pump overheats, it is too late, you need to do his before it acts up.
Try the cap trick & see what happens.
Also verify the tank is not getting hot from the exhaust.
