LS1 with different injectors
Old Jan 14, 2013 | 01:23 PM
Mista Blazer's Avatar
Default LS1 with different injectors
Would it be possible to run say a higher injector then the stock LS1 on a all stock motor except for cam and headers?
Old Jan 14, 2013 | 05:47 PM
Mrmooney's Avatar
Your tuner should be able to tune any injector to work.
Old Jan 14, 2013 | 05:48 PM
Mrmooney's Avatar
I know I have bigger injectors then I "need " right now but I did that for furture mods.
Old Jan 15, 2013 | 07:11 AM
This was more or less what I was looking for, say if I threw a much higher injector in would I.still be able to use them.
Old Jan 15, 2013 | 07:51 AM
ZL1Killa's Avatar
it absolutely must be tuned for whatever injector is installed. maximum I would run on a STOCK LS1 would be 42# injectors (rated 42# @ 43.5psi, 3bar, and at our fuel pressure of 58psi, 4 bar, they are 48# injectors)
