Fuel Pump Location for my swap?
Swapping LS in my 78 vette. I have a some room behind the front passenger fender well. I need to run a bigger line 3/8 from the tank to the engine anyway. I can then use the original fuel line as the return to tank. This would provide a little better access to pump and regulator if I have fuel problems down the road.
Does the fuel pump have to be located back by the tank? If so why?
I am also adding the Corvette regulator filter. Would an additional fuel filter harm flow if added back by the tank?
Fuel pump shut off?
Going to go in tank. Strongly considering this set up. http://www.vetteworksonline.net/cata...roducts_id=108 Then I only need one fuel line up front. Does this unit include the fuel shut off switch?
