Can Someone Confirm I wired this up correctly?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Ok, so I bought two relays to wire my Magnafuel 4303 pump. I have a fuel cell with a summit fuel sending unit. So I took off all the un-needed wiring off the stock harness, and left just what I needed to wire it up.
Just need to know if I have everything wired up correctly before I try and prime the pump.
Here's the layout...
![Can Someone Confirm I wired this up correctly?-a10v8aw.jpg](https://ls1tech.com/forums/attachments/fueling-injection/728012d1683240888t-can-someone-confirm-i-wired-up-correctly-a10v8aw.jpg)
![Can Someone Confirm I wired this up correctly?-jssntqq.jpg](https://ls1tech.com/forums/attachments/fueling-injection/728013d1683240888t-can-someone-confirm-i-wired-up-correctly-jssntqq.jpg)
Alright, so I took the trigger wire from the stock harness (grey) and connected it to 86 on the relay and jumped it over to pin 86 on the other relay as well.
Both 85 pins on the relay are jumped and grounded to the mount.
Both 30 pin's on the relay's are jumped and go to the battery disconnect.
Both 87 pin's on both relays are jumped and go to + on the pump.
Grounded the pump.
Did I do this right?
Grounded the pump.
