s10 5.3 fueling problem
I drilled and tapped the hole only to find I did not tap far enough down and another bolt broke off in the head at the exact same depth. So screw it, its staying there until i blow a head gasket or motor... LOL
These builds are also good reference for others to see what is possible and what fits well to give them better informed choices for their build.
For example: The racing innovations headers.... I would NOT buy those again. I was looking at the setup from UNDER the truck and those headers are actually designed to LET you get a crossover pipe built to run exhaust down one side of the truck.
I wanted the same thing on both sides of the truck, and that is not what I wound up with. But, lesson learned. Next build is $850 for long tube headers.
I will be back on later. Gonna eat dinner and some other things before crawling in bed and dying for the night.
You should be using the stock U arm from the turbo 400 and still getting all the gears.
I was hell bent on leaving it stock looking for some of the ultimate sleeper look, but decided I was just gonna go ahead and get a Quicksilver for the ratchet action.
