s10 5.3 fueling problem
It is still fuel deprived and that means running lean. Which could cause you some problems. Something is still amiss in the fuel system, so I would check into upgrading the size of either the power wire to the pump, or a larger fuse if it has one in line.
I just looked at napaonline.com and they actually show a regulator for BOTH 50 and 62 psi.... So some of these engines were actually set to run at the low pressures.
I looked that up on my 01 GMC yukon 5.3L specs on their website.
http://www.napaonline.com/Catalog/Re...0030%202030087
There is even a regulator that runs at 56.56 PSI..... WIERD!!!!!!!!!!!
On top of that, I looked up my friends 08 tahoe that is flex fuel and it does NOT show a regulator for that vehicle. It does show a pressure sensor connector.. but no regulator.
Congrats on getting it figured out and back up and running. I am still in the build stages on mine so I have a bit of work left to do... I wish it was less, but unfortunately its not.
I am about to go back into the heat stroke zone and find the oem exhaust pieces that have the O2 sensors and get those swapped to my header collectors, than get them bolted to the headers..
I went with a set of Racing Innovations headers. They were just $212 or a hair more.
Not too bad a set of headers, but I pointed out a couple things that could have been done differently to improve the design. Would have made for an easier installation also. Drivers side had to have the steering shaft removed to get them in, passenger side was primarily just the plug wires and dipstick out of the way. But you do have to run 45 degree plug boots in two spots that I see so far. It is all pointed out in the build pages. I even got a video of mine running the lower pressure like yours for the fuel pump. I installed a fuel pressure gauge to my fuel rail. Now I also have a spot to tap in for the wet nitrous kit as well. Just as soon as I decide to drop $500 for one of the ZEX kits that has the EFI smart box. No switches to install except the power switch. It taps into the TPS wiring for its full throttle signal. Plus, the solenoids are enclosed in the box so its a cleaner installation.
