Compression fitting for LS fuel rail?
Old Sep 30, 2013 | 12:40 PM
TableLeg's Avatar
Question Compression fitting for LS fuel rail?
I saw a discussion a while ago showing how you can fit a compression fitting onto the feed end of an Ls fuel rail once the normal fuel line connector has been removed.
The compression adaptor I remember seeing simply screwed onto the rail and was locked with a nut (on the compression side) and then had a male thread which could be attached to a -an female fitting.
Has anybody seen this type of connector and if so what size it is and where can you get one?
Old Sep 30, 2013 | 01:01 PM
Daniel Bucher's Avatar
https://ls1tech.com/forums/fueling-i...rn-bucket.html
Post #3
Old Sep 30, 2013 | 01:10 PM
TableLeg's Avatar
Daniel,
Many thanks for the reply.
It's not quite what I was looking for as the end of my rail pipe was damaged when I bought it (2nd hand, I guess the owner did it removing the old fuel clip).
The one I saw before was like a conventional compression fitting i.e. olive and nut and you could just cut the flange piece off the pipe end and fit the compression fitting.
Have you seen anything like this?
Old Sep 30, 2013 | 01:43 PM
TableLeg's Avatar
I think I may have found it
http://hotrodregal.com/wp-content/up...-00-44_881.jpg
Thanks to info from the webpage image linked above the fittings are by Swagelock
http://www.swagelok.com/search/find_...t=SS-600-6-6AN
Old Sep 30, 2013 | 02:04 PM
If you are talking about the pressure test port on the drivers side fuel rail. Its a standard an4 male fitting. If that's what your talking about you would just need a an4 female to an6 male. Fragola, Russell's, Earls. They all have those fittings. Post a picture of what is damaged, and what you want to connect to.
Old Sep 30, 2013 | 02:18 PM
TableLeg's Avatar
Thanks again Daniel,
It's the main fuel feed connection on an LS6 fuel rail. Has the same connection as this one you linked to previously
https://ls1tech.com/forums/attachmen...ussell-efi.jpg
Old Sep 30, 2013 | 02:34 PM
Hey, I guess my brain works now. This is what I think you need, requires no flare and is fairly in expensive...
http://www.jegs.com/i/Russell/799/63...07#moreDetails
Old Sep 30, 2013 | 02:48 PM
TableLeg's Avatar
That's excellent Daniel,
That'll do nicely.
Thanks very much
Old Sep 30, 2013 | 03:06 PM
No problem.
Old Sep 30, 2013 | 05:21 PM
KENS80V's Avatar
The Swagelok fitting is what you want to use. It's stainless steel as is your fuel rail.
The JEGS fitting (Russell) is only made for soft aluminum tubing. I'm using the Swagelok on my LS3 fuel rail.
Old Sep 30, 2013 | 05:24 PM
TableLeg's Avatar
Thanks for that
Old Sep 30, 2013 | 05:32 PM
KENS80V's Avatar
Most hydraulic shops sell them for about $15. You can go to the Swagelok website and they will locate a distributor close to where you live.
Old Sep 30, 2013 | 05:51 PM
TableLeg's Avatar
Thanks once again.
Old Oct 7, 2013 | 07:09 AM
TableLeg's Avatar
What size fitting is that you went with?
3/8 to ?
Old Oct 7, 2013 | 07:41 AM
Realcanuk's Avatar
Swagelok.....
Old Oct 8, 2013 | 06:23 PM
KENS80V's Avatar
Here is the fitting I used. http://www.swagelok.com/search/find_...t=SS-600-6-6AN
It is for converting a 3/8 tube to a 6AN size.
Old Oct 20, 2013 | 04:51 AM
TableLeg's Avatar
Many thanks for that KENS80V,
That's exactly what i'll need.
Old Oct 20, 2013 | 08:12 AM
Old Geezer's Avatar
AIRC, Parker has the Swageloc type fittings for less$$...
Old Oct 20, 2013 | 12:59 PM
TableLeg's Avatar
Thanks Old Geezer I'll check out Parkers as well.
