How to remove fuel rails and crossover
Old May 10, 2004 | 03:42 PM
BadAndy's Avatar
Question How to remove fuel rails and crossover?
I wanna pull them off for polishing, but I don't want to break anything in doing so. Thought you might be the guys to ask . Thanks
Old May 10, 2004 | 04:01 PM
MIGHTYMOUSE's Avatar
you'd be MUCH better off painting then polishing.. i would skip all that and get em chromed. imo.
you need a fuel line disconnect tool from pep boys etc., a 10mm socket and some rags to soak up the fuel.. also release the pressure at the shaeder valve first.
Old May 10, 2004 | 04:08 PM
BadAndy's Avatar
I've disconnected the fuel lines before so I have the fuel line tool. Why would you say polishing is a bad idea? Is it just hard to maintain or what? How much does chroming for a piece like that go?
Old May 13, 2004 | 01:02 PM
Z06PSI's Avatar
I got a set Chromed and it was 200.00 to get them prepped and triple plated. You wanna buy them? they have never been used and I can provide receipts. I will be coming that way soon for G8 anyways....?????????
Old May 13, 2004 | 05:38 PM
Nasty N8's Avatar
They can not be polished they are steel. I can offer you our billet set with all the fittings to the stock fuel lines they are already polished and with all the braided lines and fitting it looks awesome.
Nate
Old May 13, 2004 | 09:31 PM
BadAndy's Avatar
That looks bad ***. Why do I feel like it would cost an arm and a leg?
Old May 13, 2004 | 09:44 PM
Zero2Sixty's Avatar
Thumbs up to Nates Fuel Rail kit, its definitely worth showing off
Old May 13, 2004 | 09:57 PM
BadAndy's Avatar
That is definetly sweet, but how much did you get drilled for?
Old May 14, 2004 | 12:11 PM
Nasty N8's Avatar
Drilled ah? Well they are $320.00 with all the fittings to the stock lines.
Nate
