Need Injector Size Help
Old May 13, 2004 | 05:39 PM
maron blur's Avatar
Default Need Injector Size Help
I have a 2000 camaro A4 putting down 404 rwh it as stock 26.6 injectors. I am in the process of installing NOS 5177 drykit. Max. shot i will use is a 100 shot. What size injector will I need, no other modifications planned. Only reply if you know first hand from experience. NO I had a friend or my grandma's WS6 or my little sister's SS or I knew a guy. Any help would be much appreciated. Also what size plug and what gap? Thanks!
Old May 13, 2004 | 07:00 PM
AgentOrange's Avatar
Well I was using 125HP dry shot and putting down 388rwhp with my 28.8's. Its pushing it but the injectors were not max'd out. Go with some 30lbs SVOs (35.6lbs in LS1s) and you'll be well off. A Walbro 255lph intank would be a good idea too!
Old May 14, 2004 | 12:17 PM
Nasty N8's Avatar
30lbers and definatly a pump. The best your stock pump is worth is 450-475.
Nate
