Choke down 62 psi 24 gpm pump?
I am planning a 5.3 swap into my Cherokee and intend to use a 97 Blazer fuel tank, pump and strainer. The pump is rated at 62 psi and 24 (edit: gph), but I also want to use a TBI system on the 360 until I make the 5.3 swap and it runs at 15 psi.
If I restrict the 62 psi to 15, will I burn up the pump?
I am planning a 5.3 swap into my Cherokee and intend to use a 97 Blazer fuel tank, pump and strainer. The pump is rated at 62 psi and 24 gpm, but I also want to use a TBI system on the 360 until I make the 5.3 swap and it runs at 15 psi.
8 Second Truck Club
I wouldn't think it'll burn the pump up as long as you are using a bypass regulator and just pumping the unused fuel back to the tank. A good sized return will be your friend.
I'd invest in a good high flow regulator too.
After thinking about it, reducing the system pressure will probably have the opposite effect on pump life. The pump will probably like it. Less stress and more flow on the pump at lower pressures.
