converting to return style need help please
Old Mar 5, 2014 | 11:42 AM
transaminator99's Avatar
Default converting to return style need help please
i plan on putting a brfpr on the schrader valve port and using the evap hardline as return i just need help with a parts list thanks for your time
Old Mar 5, 2014 | 11:51 AM
sorry its a 99 trans am and im not sure which regulator ill be using yet and im using an aeromotive 340
Old Mar 6, 2014 | 04:48 PM
Hardcoresoldier's Avatar
not sure about running it in the evap line....For $25 you can run a hard line all the way back to the tank.
Old Mar 6, 2014 | 10:59 PM
COSPEED2's Avatar
LS1Tech Sponsor
If you are looking at making the schrader port your return then you would need this FPR. Then you would likely want some 6an line to return to the tank. Using the EVAP line is possible, but maybe a tad small. If you want to go that way though we do have some special fittings to make it work, but FIRST you need to take the reg out of your in tank setup and get rid of the stock T that returns the fuel to the tank in the first place and plug that line also or make it work as the return for your fuel system as it does in stock form.
