fuel system question y or t
Old Mar 7, 2014 | 04:06 PM
s-cam's Avatar
Default fuel system question y or t
I am redoing my fuel system and running dual 044 pumps in a -8 line to the motor. where i split the lines to run into each fuel rail it would be a much cleaner install to use a -8 T fitting then to use a Y fitting. Is there much if any flow compromise using a T fitting thats -8 on all 3 sides vs a y fitting thats -8 on all 3 sides to feed the fuel to the fuel rails? thanks
Old Mar 9, 2014 | 09:52 AM
+badss+'s Avatar
I would think the t block would disrupt the flow of fuel unlike the y blocks.
Y block is very common to use must be fore a reason.
Old Mar 11, 2014 | 05:58 PM
Cthulu's Avatar
Subscribing for data/personal experience.
Old Mar 11, 2014 | 06:04 PM
Atomic's Avatar
I need a gauge for that
Lot more head loss with a T than a Y
Old Mar 11, 2014 | 06:45 PM
The Fugitive's Avatar
I think the Y block would flow more naturally to where it needs to go. Now saying that wouldn't it be better to run a -10 that splits into 2 -8s?
Old Mar 12, 2014 | 12:58 AM
crazyelf's Avatar
For a nice y with a parallel exit look into fore innovations. Makes for a cleaner install than the traditional y block.
