Paging ScottWS6 (fueling q)
When you turn the key to power on in your car, what do you have your base fuel pressure set to?
What does it do when you crank the car, your fuel pressure stays constant right?
Please let me know.
when i turn the key it hits base, then falls as soon as i crank it is sits right where it belongs.
Not sure if this helps.
Just waiting on the coil connectors from FAST and then I'll wire in the eDIST later this week.
You should be running 43-45 base.. More than that isn't necessary, and will ultimately limit your fuel pump capacity.. (Low Z injectors and weldon pump.)
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
) 1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
I was asking Noyzee about the pump..
