LS1 car vs. truck coils?
Old May 23, 2004 | 08:21 PM
2001CamaroGuy's Avatar
Default LS1 car vs. truck coils?
whats the difference and which one is better?
Old May 23, 2004 | 09:15 PM
MIGHTYMOUSE's Avatar
i hear the truck coils are a little hotter, i still have not had any problems with stock coils.
mototron also sells factory replacement coils that are hotter than the truck ones.
Old May 23, 2004 | 09:38 PM
you mean hotter = more spark right?
why would the trucks come with a higher output coil than the Corvettes and F-bodies?
Motortron? web page/link please? How much "hotter" are their coils?
Old May 28, 2004 | 10:18 AM
smokinHawk's Avatar
dunno but they do
you need the square mitishubishi type not the round delco
you can find out more info if you do a search about them in the FI section.
Old May 28, 2004 | 11:46 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
The truck Melco ones are supposed to be hotter.
I have a set in backup for my car but so far I have had no ignition problems. You would need a set of truck wires and the coil harnesses to make this swap.
Old May 28, 2004 | 12:45 PM
http://www.mototron.com/prod_intelcoil.htm
Old May 28, 2004 | 01:12 PM
are aftermarket coils a direct swap for the LS1 "car" coils?
Old Jun 9, 2004 | 07:53 PM
smokinHawk's Avatar
depends if there plug or play or not? depends if there made for it i guess
the truck coils will swap out as they have the same connectors
