Injectors & fuel pump
Old May 27, 2004 | 07:58 PM
2000LS1M6's Avatar
Default Injectors & fuel pump
with the sts turbo kit running 5 psi will i need to get bigger injectors and a better fuel pump, or will i be fine with a good tune. if i do need them where can i buy them online and which ones are good.
Old May 27, 2004 | 09:25 PM
Nasty N8's Avatar
What kinda power levels will you be running with the kit? I can help you out if you find you need them we are running a special now on fuel system stuff.
Nate
Old May 27, 2004 | 09:50 PM
2000LS1M6's Avatar
im going to be running 5 psi.
Old May 28, 2004 | 06:26 PM
Nasty N8's Avatar
Ido not know where that kit is going to put you with 5 psi. If the car is anywhere near 450rwhp I would rec. you upgrade both the pump and injectors. Any lower than that you will be safe with the stock parts.
Nate
