1998 Fuel System
Working on a 98 T/A have some fuel system questions,
I have a 462 pontiac motor in this car. I am not running any of the LS computer stuff. With that being said how can I feed fuel to this motor? I understand the 98 stuff is different for the 99-02.
How would you feed this?? The 98 has the fuel pressure regulator built in the tank, right ?? I don't mind changing over to the 99-02 pump and tank.
I forgot to add that I am using a Aeromotive 13301 fuel pressure regulator.
Let me know what you think. Thanks, David
Use any combination of AN fittings to make the connection.
for the quick disconnect fittings on the car side.
use these Russell fittings.
http://www.summitracing.com/search?S...EFI%20fittings
