New injectors????
Old Jun 3, 2004 | 12:46 AM
HAMRHEAD's Avatar
Default New injectors????
I've had some say yes and others say no. I bought some SVO 30# injectors and wanted some opinions on whether or not to put them in. I have a 2000 Z28 with: PP stage II LS6 heads, 224/228 112 cam, LSX 78mm intake and throttle body, LT's, catback, Walbro fuel pump, 150 TNT Wet. Yes or No?
Old Jun 3, 2004 | 12:47 AM
HAMRHEAD's Avatar
Oh and a few more mods might be on the way. I figured the 30# SVO's would give me some room to grow as well.
Old Jun 3, 2004 | 06:51 PM
STANGGT40's Avatar
i'm certain that with those mods, you're in the 400rwhp range, at a minimum, so 30's would be a perfect injector for you, from what i've seen. i know a guy, here in texas, that has a similar setup, and he was running 30's, although, i would think that the injectors couldn't keep up with the 150shot, but his injectors keep up just fine...and he tunes it safely. btw, SVO injectors = Bosch, in case you're wondering. that's pretty much all i've used, until just recently.
brad
Old Jun 3, 2004 | 08:44 PM
bill99hawk's Avatar
I got the SVO 30#ers, they are actually around 36 with the high pressure fuel system in an fbody. You will need a tune though, because they dump too much fuel for the car to run.
Old Jun 4, 2004 | 07:44 AM
HAMRHEAD's Avatar
I thought they would be good to use for my setup. I am getting a dyno tune done on the car to adjust for all the mods. I'm not to worried about the 150 shot though since it is a wet kit. The upgraded fuel pump should work that end!
