Doing an E85 Only supported build. What will I need?
Old May 13, 2015 | 12:01 PM
eaglegoat's Avatar
https://ls1tech.com/forums/fueling-i...sting-e85.htmlNo one said lots of power to bad had. This setup shows that. The fuel itself does make more power. The higher the IAT the more effect the cooling will have. Unless you're octane limited you won't see a gain from adding any additional timing.
