fuel system and ls3 inj??
I read somewhere theres 3 different LS3 injector flow rates. I know theres 2 different GM factory LS3 style injectors, part#12576341 is the lower at 42 lbs @ 58 PS1 & apparently this is the same injector used in the LS7 but this link says 47 lb hr. I doubt that is accurate info. Everything else I've found on regular non boosted stock LS3 injectors is 42 lb hr @ 58 psi.
http://www.camaro5.com/forums/wiki.p...specifications
The other is 12598646, is either 50 or 52 lb hr @ 58 psi & is the ones I just bought. Those are LS9 injectors, possibly used on LSA engines as well like in the ZL1 & CTS-V. Youll see all different variations of these lil LS3 style Bosch injectors for sale at much higher flow rates, these have been reworked to flow more by fuel injector vendors.
