Optimum fuel system for my setup...
If this were your car and setup what fuel components would you use, please include as much detail as possible. This car will be driven on a regular basis when not raining etc.
Forged 6.0L , stage 3 LS6 heads, turbo cam(specs to be determined), every bolt on, T70 turbo mounted similar to the STS kit and running 20lbs of boost at the track and probably 10 on the street, engine has in the range of 8.6:1-9:1 compression, also will be using a meth injection kit. If you need more info to determine the fuel system please let me know. Thanks.
-Sly
-Sly
