Fuel pump setup good for 800whp?
Old Jan 2, 2016 | 10:01 PM
91ls1silverado's Avatar
Default Fuel pump setup good for 800whp?
I'm new to the fuel thing but I've been doing some research and wanted to make sure I'm on the right page... I have a ls1/t56 swapped c1500 truck, now I'm going to throw in a lq9 with twin 67s and I'm planning on throwing a 22 gallon fuel cell with a Automotive a1000 fuel pump. Will I be able to use my Corvette fuel pressure regulator with this setup? Running 80lb,injectors as well. Any ideas or,opinions are welcomed
Old Jan 3, 2016 | 08:18 PM
Fat Jesus 808's Avatar
The A-1000 will be close. I ran out of pump with one on a Honda at 800, but had fairly high rail pressure. And they nose dive in flow at higher pressures.
Old Jan 3, 2016 | 08:34 PM
fastassls1maro's Avatar
i have 80lb. injectors and ran out of duty cycle around 750rwhp, i was running twin wally 255's and an aeromotive afpr
Old Jan 4, 2016 | 03:28 PM
My 80's ran out of duty cycle at 700ish whp through the auto, may have been pump too though
Old Jan 16, 2016 | 01:35 PM
gtfoxy's Avatar
Is this with gas & Water/Meth?
So enough pump, just not enough injector? Base pressure & Duty cycle?
Mind if I ask what the duty cycles were & what your base pressure was?
Old Jan 21, 2016 | 09:41 PM
base pressure was set to 40psi and duty cycle was in the 90% area. This was on 18psi of boost.
Old Jan 21, 2016 | 10:05 PM
gtfoxy's Avatar
Did you try any higher pressures?
