What size injecters should I upgrade too?
Old Jun 13, 2004 | 07:43 PM
02SOMWS6's Avatar
Default What size injectors should I upgrade too?
I think my injectors are just about maxed out now. I still have the stock fuel system on the car.My H&C combo could have made more RWHP if I had bigger injectors.I'm planning on adding a TNT wet kit before the season ends.What fuel system mods do you guys think I should make.Can the injectors be turned down with tunning if too big.Might go with a S.C. system down the road so I want to spend money on injectors once.
Old Jun 13, 2004 | 10:17 PM
offaxis's Avatar
I dont think you are runing out of injector. There are lots of guys going over 450 rwhp on there stock injectors. That guy Gomer on this board made 475rwhp on his stock 02 injectors. If you do a wet kit you dont need larger injectors because it supplies its own fuel. I would put a larger fuel pump in to make sure you have a good fuel supply for the juice..
