Does this mean my fuel injector is bad?
.... The rough idle issue has now started happening even when its dry out. So.....i decided i was going to pull the intake, and install the LS6 intake i had on a few months ago (took off to pass smog). I figured while its off i could really give things a good look. When i pulled the fuel rails off the back injector on the passenger side leaked out. You can see how much and how wet it is in the pictures. Does this mean that injector is bad? It is not water, car has been covered and no rain, plus it reeks of gas. Extra info....i recently cleaned the IAC valve thinking that was the idle issue. It seemed to smooth out the cold start idle but once the car gets good and hot it really gets rough. The roughness comes and goes like the pcm is trying to compensate but can't..... And it instantly smoothes out when you step on the gas and get going.
Knackered o ring on the injector maybe?
Jim
Jim, when you say lower manifold, do you mean where the intake and the heads meet?
TLDR - you've got a manifold air leak, fix it and all will be good
Regards
Jim
I'm going to post a new thread in the general section with pictures of my spark plugs. I would appreciate your input if you wanted to stop by and chime in. I don't think anything too major was going on, I just think they are gunked up from the pcv being open.
