Cheap Injector Flow Tester DIY
So I build a simple and cheap injector tester and thought I would post it here.
I found a hose that fit tight on the rail end of the injector and hose clamped it on. Then I took a 2L pop bottle (Internet says these are good for over 100psi) and threaded/hot glued a hose barb fitting in the cap. I also threaded/glued a air fitting in the bottom of the bottle.
Next I used a cheap Arduino micro board and a relay board and connected them to a injector electrical connector and battery charger.
I wrote a program that pulses the injector 4 times a second at 75% duty for 30 seconds.
To test the injector I put some fluid in the 2L bottle (Mineral Spirits) and connected the air line with a regulator and set it to 35PSI. The bottle might be good for more pressure but I didn't want the glued fittings to blow out so 35PSI seemed good.
I put a 500ml water bottle under the injector to collect the spray and ran the program.
After the 30 second run time I marked the bottle at the fluid level and tested the other injectors to see how close the volume was at the end. Everything looked good.
Attached it a video of the operation
