Hobbs switch location? 2002 transam
Old 05-01-2016 | 12:26 PM
Patsy57's Avatar
Default Hobbs switch location? 2002 transam
Hey all I was wondering where you all would suggest mounting your Hobbs switch? I was going to T off the brake booster but then someone also mentioned this spot (see pic) on the passenger side.
Please let me know
Thanks
Old 05-01-2016 | 11:19 PM
Patsy57's Avatar
Anyone???
Old 05-02-2016 | 12:14 AM
conan's Avatar
Is this a boosted application ? Do you have more vacuume operated things to plumb in to the vac system ? Reason I ask is you could do a vacuume manifold if you need muliple feeds. If your just hooking up a hobbs you can plumb into any vacuume source.
Old 05-02-2016 | 10:49 AM
jrpimp00's Avatar
I ran a vacuum manifold off the brake booster and connected everything to it. Hid it under the fuse boxes.
Old 05-02-2016 | 04:51 PM
Patsy57's Avatar
No issues with Distance from the booster with that long of a line?
No issues with the line coming off the booster and not right after the throttle body?
Quick Reply: Hobbs switch location? 2002 transam
