Walbro 450 in 98' Camaro
My new setup is a LQ4 (basic upgrades) with an 88mm turbo (.96AR)
I am looking to only run this at 10-12 pounds and I will buy the HP Tuners software over the winter so I can learn to tune and turn it up down the road once I understand how involved the tuning is. The car will get tuned by a local shop (Straight Line in Joliet Illinois) once it is all together.
I am not running an intercooler as the car is only driven on the weekends if the weather is nice so I would really like to run E85, hence why I am looking at the 450 from Walbro.
I am seeing numbers all over the place as to what these are capable of and I'm honestly not worried about how much it puts down. My main question is, do these easily replace the walbro 255 fuel pumps, or is there modifications that need to be made to fit it. My car is a 98 camaro so I have the steel fuel tank.
I can get the pump for just over $100 which is a bit better than the $600 plus prices i'm seeing for higher horsepower levels. Like I said, I'm not looking to be ultra competitive, but I want to get the car back on the road and then I will go with a bigger fuel system next year.
Any help or insight would be greatly appreciated. Also, any real world numbers you guys are getting on certain boost levels with this pump would be appreciated so I can bring the car to the tuner without needing to have them do extra work while it's there.
here is the kit;
http://www.ebay.com/itm/WALBRO-E85-R...ZcNrvQ&vxp=mtr
New FPR, RX hot wire kit, walbro 400. Can I safely run this by upgrading the wires from the pump? Looking to make 500 with boost but if I can do it with a walbro 400 instead of a 255, it leaves room for growth and won't be stressing the smaller pump as much.
Any reassurance this should be ok? Any tips? New at wiring, so any help will be much appreciated.
Two of the four terminals on the 99-2002 replacement bulkhead connector supplied with Racetronix upgraded hot wire kits can handle 28 amps. Can it be used on a 98? NO. It requires a larger hole in the hat and secures differently to the hat compared to the yellow 98 bulkhead connector..
We recommend twin 255 or 340LPH pumps for F98/99 applications over a single W450 or W525.
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
I agree on twin pumps. To run a 450 LPH or 525 as a single pump means you recycle a lot of fuel when daily driving. Most times a 255 lph is enough for daily driving. When you need the extra fuel as you transition to boost and WOT, engage a secondary pump.
