do your duals run constantly?
I'm asking this in relation to stock fuel lined 98 camaro i want to run dual pumps on for my e85 408.
thanks in advance.
i talked to Carl at CJ tunes and he said a 450 would be fine for my 550whp engine build. any other recommendations? the 450 really only flows like 380 at my pressure and voltage. I'm sure that dual 340's flow alot more then that.but i don't want to run a switch for pumps unless i don't have to, but if a single pump will work i'll run that.
thanks for the advise.
Part of keeping the engine happy is keeping the fuel cool. You run enough fuel in the tank to keep the temp stable and only run the minimum pump output (turn down voltage if the pump can handle it) to maintain normal driving.
