Please help me understand injector sizing and regulators
Old Oct 12, 2016 | 05:47 AM
hpfiend's Avatar
Hey there- I am putting a 6.0 LQ4 in my AMC Gremlin. I am going to use a Bosch 044 pump that is fed from a sumped fuel cell. I am going to use an LS1 intake and aluminum 317 heads with a stock48 custom turbo cam. Using a y2004k gt45 turbo charger with meth injection. Probably run e85 but don't want to be committed to it as gas is a lot easier to come by. Are 80 lb ls1 style Siemens deka about right or should I go bigger or smaller? Planning on a non boost referenced c5 corvette filter regulator setup at first unless I can find a really good deal on a used boost referenced regulator.
Old Oct 12, 2016 | 05:48 AM
hpfiend's Avatar
Pointless post deleted...
Old Oct 12, 2016 | 06:48 AM
JoeNova's Avatar
Restricted User
You haven't said what your goals are.
A carb regulator won't work, it won't give you enough fuel pressure.
The stock rail mounted LQ4 regulator will work fine.
Look up injector differences. There are a few different lengths. You can use a longer injector with spacers, but you won't be able to make a shorter one work without buying adapters.
Old Oct 12, 2016 | 07:40 AM
hpfiend's Avatar
The goal is 10.30-10.80 in the quarter in around 3k or under lb chassis
Old Oct 14, 2016 | 10:53 AM
a05c's Avatar
It should be able to go in the 10's on motor
Old Oct 24, 2016 | 09:13 PM
hpfiend's Avatar
What size injectors do you all recommend?
Old Oct 25, 2016 | 08:45 AM
JoeNova's Avatar
Restricted User
80 lb deka injectors.
