what adapters are needed???
Old Dec 21, 2016 | 09:17 AM
mutang357's Avatar
Default what adapters are needed???
Ok I am doing an LS swap into my mustang, and just picked up a truck intake with stock rails and TB. Question is that I am going to go turbo with 120lb injectors, with a magnafuel 750 pump and a fuel cell. Do they make adapters to fit say a 10an feed and 8 an return? If anyone has any pictures or part numbers, I would greatly appreciate this. Or even a write up?? I have used the search function and didn't really come across anything using a bigger AN line.
Old Dec 22, 2016 | 12:10 PM
JoeNova's Avatar
Restricted User
-10 AN feed seems a bit overkill when the rail inlet is only -6.
You can get the fuel rail fittings for -6 and -8. If you want to run -10 you will just need a -6 to -10 or -8 to -10 adapter. Google should give you everything you need within 60 seconds.
Old Dec 23, 2016 | 07:24 AM
mutang357's Avatar
Default adapters
Thanks, so do you think that 8an would ultimately support 900 rwhp?
Old Dec 23, 2016 | 07:52 AM
JoeNova's Avatar
Restricted User
-6 AN has been pushed to 1600whp before.
Old Dec 27, 2016 | 09:49 AM
mutang357's Avatar
holy cow! LOL I should be good to go then.
Old Dec 27, 2016 | 10:09 AM
JoeNova's Avatar
Restricted User
Yeah. 4000 HP Pro-mods use -10 line lol.
Old Dec 28, 2016 | 11:20 PM
LilJayV10's Avatar
..........really?....
Old Dec 29, 2016 | 07:35 AM
JoeNova's Avatar
Restricted User
BMW guy using a Forced Induction Billet S484 on his inline 6 with -6 AN hardline. Fuel pressure was ~110 PSI.
With enough pressure, you can go pretty far. Pro-Mods typically use mechanical pumps and -10 line, even with methanol, to make insane HP numbers.
Old Dec 29, 2016 | 11:59 AM
LilJayV10's Avatar
That's an important part of the equation.....but I don't think that the "-6 will support 1000+rwhp" is realistic for what people are doing on here.
Dat's A LOT of fuel pressure.
Old Dec 29, 2016 | 12:51 PM
JoeNova's Avatar
Restricted User
Lots of guys making 800-1000whp here on setups that have a 3/8" or -6 AN restriction somewhere in the fuel system. Its absolutely not uncommon. My fuel system is -6 AN and with a static 66 PSI of fuel pressure and I'm somewhere around 800whp. I could probably squeeze out another 100 HP if I ever decide to boost reference the regulator.
Old Jan 3, 2017 | 09:00 AM
mutang357's Avatar
I am at odds, may just buy aftermarket rails and run e85
