Have a question with flex fuel injectors 25326903
Hello I have a set of the flex fuel injectors 25326903 on my 06 6.0 L
Psi set up the computer for those injectors.
My question is I know the fuel rail I got them off of was a return style rail and my set up is a return less one will they still work on the return less rail ?
Thank you kelly
Thank you kelly
I found out yesterday they didn’t program the pcm for those injectors it was programmed for 41 lbs injectors
i keep getting lean code on both banks and had now intake leaks any where so I called psi and that when I found out what it was programmed to.
The injectors I have is 25326903 flex fuel but I’m still confused what the flow rate is I see that one sayes 33 lbs at 50lbs and others saying they are 38 lbs.
so I have no idea what they are I sent my pcm back to psi today they are going to reprogram the injector data.
I gave them the injector number so im sure they will have the right data for them.
do you know what stock injectors flow 41 lbs?
I was just courageous
thank you kelly
thank you kelly
