Checking fuel pressure
Old May 29, 2017 | 04:54 PM
Ryanb08's Avatar
Default Checking fuel pressure
I have a 99 trans am and been having some trouble getting it to start I was gonna check the fuel pressure because my hunch is it is a fuel pump but every parts store I rent a tester from down not have the correct fitting for the schrader valve does anyone know the correct size fitting or have a link of where I could one or any advice at that fact lol thanks ahead of time for all your help
Old May 29, 2017 | 04:59 PM
rakrick's Avatar
i found out the schrader valve external thread is AN4. i went to my local hydraulic hose store and got a fitting to mate up with my gage. i did have to remove the valve stem though. it sealed up fine though. good luck
Old May 29, 2017 | 05:07 PM
Ryanb08's Avatar
Well I went out and pressed it with a screw driver and got nothing so idk would that for sure be a fuel pump or something stopped up
Old May 30, 2017 | 09:25 PM
bgw70's Avatar
Veteran: Air Force
Did you do this with the engine on or off?
Turn the key on, engine off, then do it.
$20 fuel pressure gauge.
I have one, works well, correct schrader valve hose.
https://t.harborfreight.com/fuel-inj...ter-62623.html
Old Jun 1, 2017 | 07:17 PM
joecar's Avatar
At the parts store you have to ask for a GM fuel rail pressure test gauge.
