Help!! What injectors should i be using?
Old May 30, 2017 | 03:19 PM
seniorwettway1991's Avatar
Default Help!! What injectors should i be using?
Finishing up with my LSX swap on my 94 BBody block is LQ4 bored out to 400+ Cub. inches. Have All forged Manley internals along with port and polished 243 heads, beehive springs, LSXR 102mm intake and custom grind bullet racing cam. Looking for best option for injectors. Don't want to install top of the line injectors if i dont have to but I also dont want to be pushing the injectors i do have to the max. Looking for recommendations of best injector that will get the job done with ease but not over kill and wasting money where i could save and spend on different part of my swap. Thanks in advance for help!!!
Old May 30, 2017 | 06:24 PM
farmington's Avatar
You will probably be good with 42# injectors. I used FAST injectors and haven't had an issue with them
Old May 30, 2017 | 06:36 PM
HCI2000SS's Avatar
Yep 42's will do you just fine. With my setup I'm only at around 65% cycle duty, so there's plenty of room left
Old May 30, 2017 | 06:41 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
These will fit on the FAST intake with ls2/3 rails or their billet rails with no spacers orings etc. If you need an electric plug adapter for your harness we have them also.
http://www.ws6project.com/user_stor/catalog/product_info.php?cPath=235_84_374&products_id=6741
Old May 30, 2017 | 06:48 PM
Originally Posted by hci2000ss
yep 42's will do you just fine. With my setup i'm only at around 65% cycle duty, so there's plenty of room left
would you happen to have a part number???
Old May 30, 2017 | 06:51 PM
To use an ls1 style 42lb inj youd need a spacer for the rail the spacer kit is ~$25 or so. but they do have the ls1 style connector
http://www.ws6project.com/user_stor/catalog/fast-high-impedance-36-lb-hr-injectors/
Those are FAST 42s even though they show 36lb they are 42lb at 58psi.
Old May 30, 2017 | 06:52 PM
Originally Posted by tech@ws6store
to use an ls1 style 42lb inj youd need a spacer for the rail the spacer kit is ~$25 or so. But they do have the ls1 style connector
http://www.ws6project.com/user_stor/...-hr-injectors/
those are fast 42s even though they show 36lb they are 42lb at 58psi.
i have the fast billet rail kit
Old May 30, 2017 | 07:01 PM
The fast rail will use the ls2 height inj. the previous post i made.
Old May 30, 2017 | 07:12 PM
the fast rail will use the ls2 height inj. The previous post i made.
added to my shopping cart of things i need thanks for the help guys!!!
