Fuel pump no power help
Old Jun 15, 2017 | 07:00 PM
twotoxic13's Avatar
Default Fuel pump no power help
99 Camaro has a racetronix with hotwire, It was all working fine it sat a month or so then when I tried to set the regulator I turned the key and nothing. I checked to make sure my harness was plugged in on pass kicker panel(I have done that before) it was plugged in. Checked grounds cleaned them re grounded the grounds I could find. Not sure which ones are actually for the pump. Still no power to the pump, I am getting power to the sending unit for gas gauge but it is not working. I have checked the fuses under the hood and the relays in those boxes, Is there a relay or fuse or ground I could be missing that isn't obvious? Any input or help is appreciated.. thanks
Old Jun 16, 2017 | 07:33 AM
Old Geezer's Avatar
AIRC, the RT hotwire kit has an inline fuse. It good?
Old Jun 16, 2017 | 01:14 PM
twotoxic13's Avatar
Yeah it is getting power to the relay from the hotwire kit. But the power from the stock wiring is not there to activate the relay.
Old Jun 16, 2017 | 02:31 PM
twotoxic13's Avatar
Let me ask this will it work with the assembly bot mounted in the tank?. I wouldn't think that would matter. Also i can jump the relay u see good and the pump get power and there is power going to relay? One term I am has power all the time and 1 with key on?
Old Jun 16, 2017 | 05:45 PM
twotoxic13's Avatar
Ok So I took the pcm out of the plastic I noticed when it hit metal the fuel pump would work? So is there a ground I'm missing?
Old Jun 17, 2017 | 07:04 AM
Old Geezer's Avatar
Pull the plugs out of the PCM, and take a look.
Old Jun 17, 2017 | 02:12 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
This does happen sometimes. run an external ground wire from the case of the computer to a good ground, should fix it
Old Jun 20, 2017 | 11:23 PM
twotoxic13's Avatar
Sorry to not get back sooner. I traced the wire, the ground it went to was broke off, it went to the back on the head..thanks for the help..
