Injector Question
Did they put those injectors on the 4.8?
Any help, guidance or resources would be greatly appreciated.
-Jon
If the seller claimed it is a 5.3 I would try to get your money back if that is a problem, as converting to a 5.3 involves a crank, rods, and of course new bearings.
If you are looking to build it, or reassemble, we have the parts you need at the best prices PLUS if you have 862 heads and they have a notch on the deck, we are one of the only places that offer mls gaskets that will work with them.
You other question...its def a 4.8l. l59 5.3 was a flat top but didnt come out til later. it used 243 heads also.
They did have flex fuel back then also. so its possible you have truck flex fuel inj. also all 4.8/5.3/6.0 reg inj are the same, and flex fuel same way. those are good inj and can come in handy.
I take it and a spark plug socket with me now when I buy engines. Plug it into the USB port, stick it in the hole. Helps spot the guys that are trying to sell a 4.8 as a 5.3 pretty easily.
