Eating through fuel pumps
What kills pumps? Bad gas of course. High sulfur content I hear also does the job. Sometimes excessive high pressure can wear a pump out prematurely (I run my pump as low as 35psi of fuel pressure when cruising). Also, a low voltage causes issues with some pumps.
SO I would install a $20 pump, maybe hot-wire it (always good to install a nice thick pump wire and new relay), new strainer, dump all the old gas. And finally, check the pressure once it is running, drive it and watch the fuel pressure make sure it stays where it should. "running better" on a fuller tank often says that the fuel temp is LOWER (more gas to heat up takes longer to heat up) Which may be telling you something about the fuel system overall (how do you over-heat the fuel? Bad fuel line route, ultra-high pressure, over-worked pump, things like that)
it might be as simple as a bad ground somewhere...or worse damaged wires somewhere shorting out
