aem regulator
Old Aug 11, 2017 | 02:59 AM
Dian's Avatar
Default aem regulator
i have the 25-302 regulator. would anybody know how many turns to give the screw for approx. 60 psi?
their tech doesnt know. says it depends. its weird, because the regulator supposedly comes preadjusted to 40 psi. my screw is loose.
http://aemelectronics.com/files/inst...0Regulator.pdf
Old Aug 11, 2017 | 06:46 AM
JoeNova's Avatar
Restricted User
It doesn't work that way. Pressure will vary based on things like pump flow.
You'll need to hook up a fuel pressure gauge to the regulator.
Old Aug 12, 2017 | 03:22 AM
Dian's Avatar
i was looking for something to start with. i dont have a gauge because am logging, but unfortunatly the external chanels only show up when the engine is running.
Old Aug 14, 2017 | 10:33 AM
JoeNova's Avatar
Restricted User
You can't key-on to prime the pump and check pressure?
Old Aug 28, 2017 | 09:41 AM
Dian's Avatar
no, the external chanels have some kind of problem.
well, anyway, if someone is interested: 5-6 turns take you to 3-4 bars. the regulator has a wide range, but is very sensitive where it matters. kind of hard to adjust precisely.
