Injector fuel rail help
Old Aug 27, 2017 | 09:04 AM
Gav's Avatar
Gav
Default Injector fuel rail help
Hi,
I am hoping one of you could enlighten me on what my Injectors and fuel rail are.
Have ls6 block, 241 heads mildly ported, holley 90mm tb and 224r cam self tuned so far with efilive on ls1 swap kit car.
Have found out that the intake is actually a
LS2 as part number on it is 12589181 and from here
http://www.lsxmag.com/tech-stories/e...ake-manifolds/
The fuel rail has on it a sticker showing Bosch 982 F00H F00 028
This is just so i could see my options if i were to get a Fast 90,92 or 102 intake and if it would be worth upgrading to the Fast.
Regards
Gav
Old Aug 27, 2017 | 09:40 AM
01ssreda4's Avatar
Please post a pic of the rail
Old Oct 23, 2017 | 11:07 AM
Gav's Avatar
Gav
Sorry for long response, have hopefully attached a few piciesInjector fuel rail help-20171023_165832.jpg
Old Oct 23, 2017 | 06:04 PM
Crf450r420's Avatar
That looks like the stock stainless LS2 fuel rail. The LS1 were black with a dampner.
Old Oct 24, 2017 | 10:55 AM
Gav's Avatar
Gav
Thanks for looking.
Any idea what injectors might be, as can see from pictures have blue o ring on them.
Regards
Gavin
Old Oct 24, 2017 | 05:29 PM
Crf450r420's Avatar
Can't see enough, but there were stock injectors with the blue ring, like the LS2's and maybe others. There should be an 8 GM number on them you can google to get info. The LS2's were like 34lb at 58 psi.
Old Oct 25, 2017 | 08:22 AM
01ssreda4's Avatar
You can get someone to look in your tune for injector data to give you an idea if they are stock or aftermarket. What connector is on them?
Old Oct 25, 2017 | 03:40 PM
Gav's Avatar
Gav
Hi,
I got efilive and tuning it myself. What tables should i look in to reference lbs injectors, havnt seen this info? Also i have tuned with AutoVE with my wideband.
What do you mean what type connector?
Regards
Gav
Old Oct 25, 2017 | 04:22 PM
Crf450r420's Avatar
The wiring will connect to the injector with a square Bosch connector or a more rounded UScarr connector.
If you have not setup the injector info, did someone else do it before you?
Old Oct 26, 2017 | 08:00 AM
01ssreda4's Avatar
Look under (i have hptuners but it should be similar) > Engine > Fuel > General > Injector Control Flow Rate vs. KPA
For your connector type, which will give us an idea of what body style injector you have, see here:
https://sites.google.com/site/sloppy...-injector-info
Old Jul 21, 2018 | 10:34 AM
Gav's Avatar
Gav
Hi,
thought time to revist
has 1248049 on them but hard to read.
Look like these https://www.ebay.com/p/Fuel-Injector...8049/169390464
so 32lbers then ?
regards
gav
Old Jul 21, 2018 | 01:37 PM
Luke19901's Avatar
.look like 33 lb/hr LS2 injectors.
being LS1 PCM and dead head fuel system your data should look like
File Type: pdf
Old Jul 31, 2019 | 02:34 PM
Gav's Avatar
Gav
It doesnt look like that, about one decimal place out....
Perhaps if i post screenshots of my injector data would anyone be able to help?
If i go turbo, will need to know which type 60lb to get for straight swap, i know i need to reprogram the injector data as well.
Pity the pound/dollar rate is so crap atm, unless i can get some equivalent ones in uk...
Regards
Gavin
Old Aug 3, 2019 | 11:36 AM
Crf450r420's Avatar
It's pretty easy to put taller injectors as you can just space the rail up and use longer bolts. Shorter injectors need an extension you would have to buy. There are many stock height larger ones also, I believe FAST has some as well as others I'm not thinking of right now.
