what causes injectors to go wide open
what would cause injectors to go wide open at any throttle position while on the throttle ? Idle is normal. tps voltage changes from .55v at 0% and voltage rises with % of throttle. with Hp's VCM scanner logging i only see the LTFT and STFT not right compaired to previous logs and they peg out at 20.6 when on the throttle. all other readings look normal. any help would be great!
