Fuel pump voltage drop at WOT
Old Sep 2, 2017 | 01:27 PM
Kevin Courtright's Avatar
Default Fuel pump voltage drop at WOT
Recently I installed a new racetronix fuel pump kit in my 2001 camaro. Everything was going good when it was getting tuned until the car made around 400whp and I was losing voltage which was making the car go lean. It would lose voltage around 6000 rpm. All the grounds look good so I was thinking it may be that the alternator isn't strong enough for the fuel pump. Just seeing if anyone has had the same problem as I am having.
Old Sep 2, 2017 | 02:45 PM
How many amps is the pump pulling?
Old Sep 6, 2017 | 08:33 PM
joecar's Avatar
At higher rpm alternator might be challenged/failing.
Old Sep 7, 2017 | 02:01 PM
Dian's Avatar
i measured 10a for the 255 pump at 12.1v.
Old Sep 14, 2017 | 07:38 AM
NOBR8KSS's Avatar
Did you connect the pump wiring directly to the alternator? or did you use another point?
Old Sep 19, 2017 | 01:31 PM
stevieturbo's Avatar
So what it seems that you are saying...without saying it. Is that your alternator may not be charging at high rpm.
Old Sep 20, 2017 | 11:04 AM
joecar's Avatar
Someone was explaining to me that some brushes lose contact with the slip rings at higher rpm...
I'm not sure of the details, I'll see if I can find out more.
Old Sep 20, 2017 | 02:25 PM
Possible, but it does seem that some alternators are just problematic, whether it's brushes, regulators, or other internal parts.
There have been a few threads on similar problems and I've had it myself, but with no real reason as to why.
