210lb injectors pump gas
Old Sep 11, 2017 | 08:43 PM
Armyrick92's Avatar
Default 210lb injectors pump gas
My goal is 1000WHP out of a LQ9 twin VSRACING 63/76. Do you think the 210lb bosch injectors are to big for pump gas? I was looking at the 160lb bosch injectors but everyone says they have problems with them so I was looking at the 210lb from bosch. I will be running 93 octane with water/meth injection on the street.
Thanks ahead of time.
Old Sep 12, 2017 | 12:36 AM
slowlsx's Avatar
Make you a good deal on some FID1300's, have less then 100 miles on them. Pm me if interested!
I think 210's is a ton of injector for pump gas
Old Sep 14, 2017 | 04:48 PM
roastin240's Avatar
Forcefed86 told me that people are idling them on pump gas cars even on the 5.3 so I would imagine you will be okay on a 6.0 setup. Keep in mind if there is a 3-5 % flow difference (typical of off the shelf injectors before matching them), this equates to huge AFR variance especially at low pulsewidths. Give them a shot and let us know
Old Sep 19, 2017 | 01:39 PM
stevieturbo's Avatar
Be more specific about which injector people are not happy with, and what you want. There are many options.
Good quality 2000cc injectors controlled by a good ecu should not pose any real problem for you.
Of course if you only want 1000hp, WTF do you need 2000cc injectors for ?
Old Oct 11, 2019 | 12:58 AM
Ford_Assassin's Avatar
Looking into these for a twin turbo setup using a Holley Terminator ecu on 91 for Street driving, but e85 for track use.
Old Oct 11, 2019 | 04:59 PM
AUS Injection's Avatar
You do not need 2200cc (210lb) injectors for your set up!
Old Oct 11, 2019 | 05:03 PM
A 1200cc-1300cc injector would work great for you on pump gas & leave you room for growth as well.
Old Oct 12, 2019 | 07:54 AM
joyridin''s Avatar
You are replying to a 2 year old post.
Old Oct 15, 2019 | 10:30 AM
Whoops . . .
Old Feb 15, 2020 | 04:55 PM
johndavid24's Avatar
two years or ten ....i was learning something ....time only matters on the stock market , while i'm here what injector size for a safe 800 hp on a all forged 97 LT1 383 ?
If I'm close to 500hp NA now
Old Feb 24, 2020 | 12:18 PM
AndyTA's Avatar
Depends:
Pump gas/E85/What?
800 at the crank?
80lbs will get you there even with E85.
I'm currently around 800 at the tire with 80lbs on pump gas. 92% duty
Old Feb 25, 2020 | 09:52 AM
92% isn't the end of the world but max duty cycle for safety reasons would be at 90%. Maybe 1000cc injectors would be perfect for your setup.
