Delphi 25317628 standard vs. Denso 12580426 felx fuel injectors for cam only 5.7 LS1.
I'm helping my little cousin collect the parts for his schools budget project and I need to choose the injector to use. It will be stock rebuild iron LS1/853 heads with truck intake,ms3 cam and longtubes. The fuel system will be a racetronix pump set up with a vette fixed 58psi filter/regulator.
I have two sets of truck rails and injectors.
One has the gas 25317628 22lb/hr injectors and the other is the flex fuel 12580426 36 or 38 lb/hr @ 58psi.
Any benefit to the e85 injectors with this mild set up?
Have you calculated the fuel demand for this setup? That will help answer your question
Well my math isn't very good to begin with but not knowing the hp doesn't help much either. I was hoping someone had a similar set up and could chime in. Ballpark hp would be what? Maybe 400 at the flywheel?
