Question on 02 tank/lines
Old Oct 11, 2017 | 09:12 AM
02ws666's Avatar
Default Question on 02 tank/lines
Hello all,
I have gotten my 02 tank dropped in preparation for installing the dual 450s and new feed and return lines. The Chrs1313 fuel pump setup I have will utilize the stock wiring.
What all do I need to do with the evap stuff? What can be Unplugged? Capped? Removed? Relocated?
This is alot of pieces for a system that will only have 2 lines coming from it once I am done. Curious what everyone does with the stock stuff.
2002 Tank/Lines
Old Oct 11, 2017 | 09:41 AM
01ssreda4's Avatar
Heres my before and after. Leave the one vent for air relief when filling. Remove everything else. No fumes so far.
Old Oct 11, 2017 | 09:57 AM
02ws666's Avatar
Thank you for the quick reply. This looks like what I will do exactly. What did you plug the 2 lines with right below the pump?
Old Oct 11, 2017 | 10:05 AM
01ssreda4's Avatar
I installed it just like that in the pic. No issues so far and Ive already gone through 30 gallons of e85.
Old Oct 11, 2017 | 10:30 AM
02ws666's Avatar
Oh ok wasnt sure if you put a cap on the larger piece pointing to the right. Thanks for the info!
Old Oct 20, 2017 | 05:51 PM
imma_stocker's Avatar
If you drive in dusty or sandy conditions I'd also suggest putting a cheap filter on the open lines. Or do what I did and zip tie a piece of rag around cut hoses.
Removing evap stuff will require tuning out those codes. And you might as well remove the rest of the system.
