Need help with fuel
Old Oct 25, 2017 | 11:46 AM
SSjohn415's Avatar
Default Need help with fuel
I'm doing an ls swap into my Monte Carlo SS (86), I have a stock 07 ls2 im getting 80 psi fuel will that stop my injectors from working??? When I crank it the engine doesn't fire up, i sprayed starting fluid and the engine fired right up. I Need some help please.
Old Oct 25, 2017 | 04:25 PM
Crf450r420's Avatar
How is your fuel system setup in the car? What are you using to regulate the fuel pressure?
Old Oct 25, 2017 | 05:01 PM
SSjohn415's Avatar
I have a isr fuel regulator on a returnees system
Old Oct 25, 2017 | 06:09 PM
Crf450r420's Avatar
Returnless systems only work with PWM fuel pumps. EFI needs high pressure and those pumps need fuel flow to keep cool if they ran constantly.
Old Oct 25, 2017 | 06:19 PM
SSjohn415's Avatar
will I be ok if I tie into the return line
Old Oct 26, 2017 | 09:39 AM
Crf450r420's Avatar
You need to have a return. That will keep the pump flowing and cool, plus allow you to adjust the fuel pressure to more standard pressure.
Old Oct 26, 2017 | 10:07 AM
SSjohn415's Avatar
I'll just uncap my return and tie end to it. So once I get the pressure right my injectors should kick on or do you think they are possibly clogged ???(I had the engine at least 6 months before I installed it)
Old Oct 26, 2017 | 08:47 PM
Crf450r420's Avatar
Unless junk got into them they shouldn't be clogged, but they can be stuck. A battery to each and listen for a click, if they don't tapping on them can free them up.
Old Oct 26, 2017 | 08:51 PM
SSjohn415's Avatar
ok I'm on it right now
Old Nov 2, 2017 | 06:13 PM
SSjohn415's Avatar
I connected to my return set the regulator to 60psi and it still only start with starting fluid
Old Nov 2, 2017 | 09:53 PM
Crf450r420's Avatar
If you have fuel at rails and pressure is okay. The only things that can keep out of the motor normally would be injectors stuck or EFI computer/harness issue. Put a test light in place of the injector and crank it, light should pulse. If it pulses, just injectors with a 9 volt battery.
Old Nov 5, 2017 | 11:52 AM
SSjohn415's Avatar
when put my test light on the injector harness the comes on and at the fuse box when cranking theres' no light at all
Old Nov 5, 2017 | 11:58 AM
SSjohn415's Avatar
the hole fuel box has no power during cranking
Old Nov 5, 2017 | 02:29 PM
Sounds like during cranking, there is no power. Make sure there is power WHILE cranking AND after startup.
Old Nov 5, 2017 | 02:45 PM
Crf450r420's Avatar
Yeah, really old cars with points you can have an issue trying to install EFI because some things don't maintain power while cranking. The ECU, injectors, fuel pump, and coils must have power while cranking. If it has power with key on then you likely have an ignition switch issue or maybe a weak relay. Oh, unless your voltage is dropping below 10 volts, sometimes it's 8 volts that is an issue, but if it stays 10 or above it's not a problem.
